Is there a way to change the playback speed each time a loop repeats?
I use Audacity for learning new instrumental music. What I would like to do is loop a slowed down clip and have it speed up by an incremental amount each time the loop repeats. e.g. 1st time playback at -50%, 2nd loop at -45%, 3rd loop at -40%, etc.
The only way I’ve found to do this is to select a clip, apply the Repeat function x-number of times, then select each of the Repeated clips in turn and apply a specific precision Tempo to each. It works but is cumbersome to set up. Seems like there should be a more automated method.
