ChangeSpeed Not Working in Scripting in Python
Hi all,
I’m using pyaudacity to batch edit some files in Audacity using the mod-script-pipes functionality. My commands in general work fine, with the exception of the command where I use ChangeSpeed:
import pyaudacity as pa
import time
filename = "/absolute/path/to/file/test.mp3"
savefilename = "/absolute/path/to/file/test_short.mp3"
# New window
pa.do('New')
# Import the file clip
pa.do(f"Import2: Filename=\"{filename}\"")
# Select the clip
pa.do('SelectAll')
# Change the tempo
pa.do("ChangeSpeed: Percentage=\"-10.0\"")
# Change the pitch
#pa.do(f"ChangePitch: Percentage=\"-10.0\"")
# Export
pa.do(f"Export2: Filename=\"{savefilename}\"")
pa.do('Close')
The frustrating thing is that if I run the ChangePitch command instead (which is commented out there, but has the same arguments), the entire script works fine (resulting in a -10% change in pitch in the saved mp3 file). I think maybe the name of ChangeSpeed effect has been changed without an update in the documentation, but I’m honestly not sure. Here’s the error output for the ChangeSpeed line:
PyAudacityException                       Traceback (most recent call last)
Cell In[14], line 19
    16 pa.do('SelectAll')
    18 # Change the tempo
---> 19 pa.do("ChangeSpeed: Percentage=\"-10.0\"")
    21 # Change the pitch back up
    22 #pa.do(f"ChangePitch: Percentage=\"-10.0\"")
    23 print("e")
File ~/miniconda3/envs/ncg/lib/python3.13/site-packages/pyaudacity/__init__.py:137, in do(command)
   135 # sys.stdout.write(response + '\n')  # DEBUG
   136 if 'BatchCommand finished: Failed!' in response:
--> 137     raise PyAudacityException(response)
   139 return response
PyAudacityException: Your batch command of ChangeSpeed was not recognized.
I’m using Audacity 3.7.3, on macOS Sonoma 14.7, and Python 3.13.2. I’m assuming this is an issue with something on Audacity’s end, rather than PyAudacity, since I also tried these commands using the do_command function defined in pipe_test.py, and I get the same pattern where ChangeSpeed doesn’t work, but ChangePitch is fine. I can also use Change Speed and Pitch just fine through the GUI.
Thank you for your help!
That library is the problem. I love the developer’s books, but the code in that module is fragile, has not been updated since March 2023, and is now broken.
I thought so too, but I also can’t run ChangeSpeed it using the code from Audacity (adapted from pipe_test.py, which is from Audacity’s github):
import os
import sys
if sys.platform == 'win32':
    print("pipe-test.py, running on windows")
    TONAME = '\\\\.\\pipe\\ToSrvPipe'
    FROMNAME = '\\\\.\\pipe\\FromSrvPipe'
    EOL = '\r\n\0'
else:
    print("pipe-test.py, running on linux or mac")
    TONAME = '/tmp/audacity_script_pipe.to.' + str(os.getuid())
    FROMNAME = '/tmp/audacity_script_pipe.from.' + str(os.getuid())
    EOL = '\n'
print("Write to  \"" + TONAME +"\"")
if not os.path.exists(TONAME):
    print(" ..does not exist.  Ensure Audacity is running with mod-script-pipe.")
    sys.exit()
print("Read from \"" + FROMNAME +"\"")
if not os.path.exists(FROMNAME):
    sys.exit()
print("-- Both pipes exist.  Good.")
TOFILE = open(TONAME, 'w')
print("-- File to write to has been opened")
FROMFILE = open(FROMNAME, 'rt')
print("-- File to read from has now been opened too\r\n")
def send_command(command):
    """Send a single command."""
    print("Send: >>> \n"+command)
    TOFILE.write(command + EOL)
    TOFILE.flush()
def get_response():
    """Return the command response."""
    result = ''
    line = ''
    while True:
        result += line
        line = FROMFILE.readline()
        if line == '\n' and len(result) > 0:
            break
    return result
def do_command(command):
    """Send one command, and return the response."""
    response = get_response()
    print("Rcvd: <<< \n" + response)
    return response
filename = "/path/to/test.mp3"
savefilename = "/path/to/test_short.mp3"
do_command('New')
do_command(f"Import2: Filename=\"{filename}\"")
do_command('SelectAll')
do_command("ChangeSpeed: Percentage=\"-10.0\"")  # This throws the error
#do_command('SelectAll')
#do_command("ChangePitch: Percentage=\"10.0\"") # This doesn't when uncommented
do_command(f"Export2: Filename=\"{savefilename}\"")
The output of the above is as follows, you can see the command doesn’t work using the script from Audacity’s github:
Write to  "/tmp/audacity_script_pipe.to.501"
Read from "/tmp/audacity_script_pipe.from.501"
Send: >>>
New
Rcvd: <<<
BatchCommand finished: OK
Send: >>>
Import2: Filename="/path/to/test.mp3"
Rcvd: <<<
Send: >>>
SelectAll
Rcvd: <<<
Send: >>>
ChangeSpeed: Percentage="-10.0"
Rcvd: <<<
Send: >>>
Export2: Filename="/path/to/test_short.mp3"
Rcvd: <<<
Exported to MP3 format: /path/to/test_short.mp3
So the issue is seemingly with ChangeSpeed, not the module.
The name of the command has changed from ChangeSpeed to ChangeSpeedAndPitch, but they didn’t think to update the documentation.
