Change Tempo on 40 files
I have 40 files that I want to batch apply a speed change “Tempo” to them.
I made a macro, and when I run it it seems to be making the changes on each file. but I don’t know if it is saving them and if it is where.
Does you macro include an “Export” command at the end?
To show us your complete macro, export the macro from the Macro Manager, and then either attach the exported file to your forum post, or copy and paste the contents of the exported macro into a forum post.
Ok I think I was missing the export, (#2) in it now? I can’t test it right now, but the #2 line was missing before.
Where will it save the modified files?
The default location for each platform are given here: Directories Preferences - Audacity Manual
