Change Pitch not working
Ever since the last couple of updates on Audacity the CHANGE PITCH only effect does not work at all. The only way to change the pitch is to select the CHANGE PITCH AND TEMPO option, which is not working for me. Anybody have an idea how to fix this bug?
I’ve tried multiple things, such as restarting, updating, still the same problem
Did you select the audio (usually “select all”)?
What’s happening? Any error messages, or does it “look like” it’s processing and then there is no change? Etc.?
How much are you trying to change it?
…Those effect are built-in and they SHOULD work.
Yes, I selected all, and used the change I’ve been using for the past several years, merely changing a small amount. There is no error message; the audio simply doesn’t change pitch. The only way to change pitch is to select change pitch AND tempo. A real pain.
I’ve also tried uninstalling and re-installing Audacity, still to no effect
“Just for fun”, try changing it by 50% (or something obvious) to make sure it’s not doing anything at all.
It doesn’t give me percentage options, just musical note options
Changing the percentage worked! Thanks
