Change in sound between Realtime Effect and Applying Effect
Hi! I’ve recently noticed a large discrepancy in quality between using certain plugins as Realtime Effects versus applying the effect. For example, I recently purchased the Laboga Diamond Sound suite from Aurora DSP. When I add the plugin as a realtime effect, it sounds great. Because it uses a lot of memory, I prefer to apply the effect in order to free space for the rest of the project. Once I do that, the quality sounds much worse on the track, almost like dropping from 320k to 128k. Does this has something to do with the plugin or Audacity? Thanks!
In Audacity some realtime plugins use the default settings when applied, rather than the settings you have carefully crafted and can hear in the preview.
A possible workaround is to save your settings as a preset in the plugin to make them persist, (not guaranteed).
AirWindows has a range of free amp sim plugins which work in Audacity, (no eye-candy).
Hi Trebor! Thanks for following up! My issue is that both the plugin added as a Realtime Effect and the plugin applied to the entire track have the exact same settings yet sound very different. I would be happy to send over a screenshot or audio example of the issue that I’m experiencing.
I should also add that the discrepancy is sound also occurs when exporting the file. If I have a specific Realtime Effect added to a track and export the file, the drop in sound quality also occurs only on that track.
Audacity is not compatible with some VST3 plugins.
If you have the option use a VST2 version of the plugin: it’s more likely to work properly.
It sounds “very different” because the plugin has reverted to the default settings when applied.
Thanks! I dropped the same track into Reaper, applied the plugin in question, and did not notice any change in tone once rendered. Bummer, as I love using Audacity but not being able to properly use important plugins really dampens the experience. Thanks for all of your help!
“In Audacity some realtime plugins use the default settings when applied…”
Wait, what? I thought I was losing my mind - noticing the same behaviour as the OP.
Are we talking bugs here, or is this by design?
It’s a bug with some, (not all), VST3 plugins.
Awreety, awrity,
Time to revisit my latest projects… Thanks!
