Change default encoding when exporting
If this exists already, i’d like help finding it. If it doesnt exist, I request that it begins do so. I wanna change the default encoding when I export certain filetypes. For example, I can’t use LMMS with certain encodings, and the ones it cant use are exactly the first two or three encodings. That’s frustrating, but not a problem if i can just change this one behavior to better fit my needs.
When you change the export format and encoding, it saves that as the new default the next time you export.
