"Censor Beep" Options
I edit dialogue and am looking for different options for a “censor beep.” For example, @steve has a great plugin, Wikki-Warp, that manipulates pitch and speed and I’ve found works well.
What do you do when you have a word that’s not suitable for your project?
select the audio you want to get rid of, Generate → Tone. 1000 Hz sine is the standard used in broadcasting for censor beeps.
