Cell phone interference click removal
Hi, I have this audio file where there’s consistent clicking caused from (what I guess) is cell phone interference. I can see the clicks in the spectrometer, but I don’t know how to remove them. Any help would be appreciated.
macOS 10.15.7
Audacity 2.4.2
If your life depends on it, try the Repair effect.
If it’s less important than that, then it’s probably not worth the effort, though you could try this “Declicker”: https://forum.audacityteam.org/t/updated-de-clicker-and-new-de-esser-for-speech/34283/1
