CD-R burning with markers and no gaps
I’m brand new to Audacity so please don’t be too technical if any answers are forthcoming.
I’ve used the Acoustica sound mixer for years where I can number the tracks on my CDs.
Can I burn a gapless CD with track numbers on Audacity?
You can number (and name) the tracks in Audacity and then export them. However, Audacity is not a CD burning app; you may need additional software.
A free solution would be iTunes (also available for Windows), where gapless burning is possible. Export your files from Audacity to any iTunes-compatible format (.wav, .aiff, etc.) and then burn in iTunes.
I make one continuous WAV file and then I use ImgBurn with a Cue Sheet to set the track markers.
(Some burning applications may not support cue sheets.)
A cue sheet is a plain text file so you can create/edit one with Windows Notepad. I usually start with a known-good cue sheet and edit it.
