hi
I’m an experienced digital photographer and PC tutor;
but I need some advice on using Audacity.
I have used it for basic LP vinyl records to HD and CD-ROM conversion, no problems there.
Then I thought - I could make my own silly voice clips for another project
(OK its not a serious beardy project, just for fun and uploading to an animation site)
I’d like to take a couple of clips and turn them into silly voices, cartoon like.
Any idea how to do this from the basic Audacity tools?
and is there a useful plug-in that might help? pitch variation etc.
I know just speeding it up makes the pitch higher, but also shorter and hard to understand and I know the old tape editing way of speaking slowly
then speeding up the thing -but that’s not quite so useful, in fact that’s the Alvin and the Chipmunks trick
All tips apprecated
Failing that -is there another freebie software that will do the trick?
Archie
Thanks
