Cant use Spitfish plug in
I cant use the spitfish plug-ins it tells me that theyre not found but im supposed to have done it right…
17:05:41: Audacity 3.1.3
17:05:41: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
17:05:42: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Le module spécifié est introuvable.)
17:05:42: Error: Failed to load avformat-58.dll (error 126: Le module spécifié est introuvable.)
17:05:42: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Le module spécifié est introuvable.)
17:05:42: Error: Failed to load avformat-57.dll (error 126: Le module spécifié est introuvable.)
17:05:42: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Le module spécifié est introuvable.)
17:05:42: Error: Failed to load avformat-55.dll (error 126: Le module spécifié est introuvable.)
17:05:46: Loaded 79 string 1,880859 Kb in size
17:05:46: Project loaded in 158 ms
17:05:59: Error: Failed to load shared library ‘C:\Users\Joey Bédard\AppData\Roaming\audacity\Plug-Ins\FLOORFISH.dll’ (error 193: %1 n’est pas une application Win32 valide.)
17:06:03: Error: Failed to load shared library ‘C:\Users\Joey Bédard\AppData\Roaming\audacity\Plug-Ins\BLOCKFISH.dll’ (error 193: %1 n’est pas une application Win32 valide.)
17:06:04: Error: Failed to load shared library ‘C:\Users\Joey Bédard\AppData\Roaming\audacity\Plug-Ins\SPITFISH.dll’ (error 193: %1 n’est pas une application Win32 valide.)
Spitfish is only available in 32-bit format.
Audacity is now available in 64 & 32-bit versions,
(if you must have 32-bit plugins, you need 32-bit Audcaity).
Here are free 64-bit de-esser plugins, (replacements for spitfish), I have used in Audacity on Windows …
T-DeEsser plus … 'T-De-Esser Plus' free VST (free crippled version)
Toneboosters V3 … https://youtu.be/5fffEP5-N5o (2 de-esser plugins, 1 simple & 1 complex, both fully functional).
