Can't start to play
Hi,
I’m using Audacity 4 alpha 2. And I found a problem. This is for feedback and I don’t hurry the fix because there is a workaround.
Sometimes playback doesn’t start when I push play button. it does start after once I quit Audacity and relaunch it.
My environment is
  • MacBook Pro
  • macOS Tahoe 26.2
  • Apple M2 tip
  • 24 GiB memory
My project contains three track from three audio files whose duration is about one hour. I use Audacity to edit podcast episodes.
Feel free to tell me if I need provide more information.
Thank you.
Using an alpha (not even beta) version for tasks where you need a real result is not recommended. And Audacity 4 is in a very early stage of development. As I can see from other contributions in this forum, there are even not all functions implemented which should be.
Your best choice is to use a final version of Audacity (I am using 3.6.4, but 3.7.7 is available).
For reports on alpha / beta version, you’d probably need to go to their Github or whatever site and report them there. If someone knows the correct address, please let it know to KitaitiMakoto.
Thank you for reply.
I know I shouldn’t use alpha version for real result. I filed this because this might help if developers don’t recognize this issue.
Of course, I will file a issue on GitHub if it is more proper.
I found similar issue on GitHub: Pressing Space doesn't start playback · Issue #10332 · audacity/audacity · GitHub
I will keep my eyes on that.
