Cant save in any other way but aup3
i try to save but the only format is aup3, i cant export it in davinci resolve and cant use an mp3 convertor as the file isn’t accepted, pls any help?
If you “Export”, rather than “Save Project”, you get the WAV option …
DaVinci Resolve has an audio program built in called Fairlight. Although it has a much steeper learning curve than Audacity does.
