I have installed Audacity on my new computer windows 11. When I press record a message comes up “Error opening recording device. Error code: 0 Success.” I have checked that microphone is will accept Audacity and it does. Have uninstalled and reinstalled. It works fine on my old win 11 computer .
(Post 1 of 3)
Not sure if this works with Windows 11. I have 10 and all of the info I could find on here was for previous versions of Audacity. This is for 3.2.5 version. Since I’m new, I can only put one imbedded item per post.
Click on Audio Setup, then on Audio Settings.
Yes, as Shatosa has indicated, Change your Host to WASAPI.
Thank you Shatosa changing my Host to WASAPI fixed it.
And thank you Jademan, it worked all good. Cheers Ian
Welcome. I’m glad it was an easy fix.
