Moderator: Split to new topic on Windows board and given relevant title
I need some help…I have to make some voice over recordings and all I have is an audio-technica AT2020 USB mic (at least for now until I buy a conventional one). I am running Windows 10 on my PC. For some reason, Audacity recognizes my microphone (I can see it and select it from the pull-down menu), but I can’t record properly. The recording is very very faint with a lot of hiss. It’s as if something is blocking it (??).
In case you don’t know this, a “conventional” studio or stage mic won’t work properly with the mic input on a laptop or regular consumer soundcard. You’ll need an [u]Audio Interface[/u] with a proper low-impedance, balanced (3-wire) microphone input and an XLR connector. Or, you can use a preamp or mixer with a proper mic input and connect the line-output on the preamp/mixer into the line-input on your soundcard.
I have Audacity 2.1.1 and I do know that I need an interface along with the conventional mic, but I need to record with this USB mic for now until I can afford to buy the other stuff. And yes, my record levels are up all the way.
