17:27:33: Audacity 3.4.2
17:27:33: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
17:27:33: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
17:27:33: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
17:27:33: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
17:27:33: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
17:27:37: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
17:27:37: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
17:27:37: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
17:27:37: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
17:27:37: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
17:27:37: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
17:27:40: File name is C:\Users\charl\OneDrive\Desktop\Call of Duty®-2024_03_22-16_58_48.mp4
17:27:40: Mime type is *
17:27:40: Opening with libav
17:27:40: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
17:27:40: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
17:27:40: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
17:27:40: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
17:27:40: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
17:27:40: Opening with legacyaup
17:27:40: Opening with libsndfile
17:27:40: Opening with liboggvorbis
17:27:40: Opening with libopus
17:27:40: Opening with libflac
17:27:40: Opening with libmpg123
17:27:41: Opening with lof
17:27:41: Opening with libwavpack
17:27:41: Error: Importer::Import: Opening failed.
Nov 16 2023
Commit Id:
9dd60f of Thu Nov 16 14:58:21 2023 +0300
Build type:
CMake Release build (debug level 1), 64 bits
Compiler:
MSVC 19.37.32825.00
Any ideas?
