I have an Audacity Project (AUP file & _data directory) which I’ve been happily using for some time. Here are the names:
“whitenoise 5+ halfspeed.aup”
“whitenoise 5+ halfspped_data/”
Notice that the names don’t agree completely because I misspelled the project name when I first created it, then changed the name of the AUP file. I did that long ago and the project continued to work properly. Today, I needed to share the Project with someone else, so to avoid confusion I changed the name of the “whitenoise 5+ halfspped_data” directory to match the name of the AUP file, so the new name is “whitenoise 5+ halfspeed_data”. Next I used a text editor to change the 3rd line of the AUP so that ‘projname’ referred to the modified directory name.
Next I double-clicked the AUP file but found that Audacity wouldn’t load it, instead I would get this error:
Error Importing:
“D:\whitenoise\whitenoise 5+ halfspeed.sup” is an audacity project file. Use the “File>Open” command to open Audacity projects.
If I followed the Error pop-up instructions, I would get exactly the same error.
I poked around your wiki and this forum and saw the recommendation to install version 3 (I was running 2.4 I think), so I did that. But the new version gives me this error:
Error Importing:
Audacity did not recognize the type of file ‘D:\whitenoise\whitenoise 5+halfspeed.aup’.
Try installing FFmpeg.
For uncompressed files, try File>Import>Raw Data
I re-installed FFmpeg, then tried again and got this message:
Error Importing:
I tried importing as Raw Data and get a 1/2 second waveform that sounds like a mosquito buzzing in your ear (the original project is around 5 minutes of audio).
I’m attaching my AUP file. (The audio file directory is 227 MBytes so I’m not trying to attach that.)
Please help!
whitenoise 5+ halfspeed.aup (35.7 KB)
