suddenly I can’t move a new file to my itunes library. it worked FINE previously.
What’s the format? WAV?, MP3?, etc?
What’s your operating system?
Does it play in iTunes or other audio player without adding it to the library?
format is .aup3 or compressed zip file (converted to zip, attempted to move into itunes but that didn’t work either) windows 11. NO, files won’t play at all. this is a problem I didn’t experience b4
.aup3 is an “Audacity Project File”. It contains all the information, including all the steps you did to your music. But it is not a music file. And iTunes also cannot deal with .zip archives.
Export your music in your preferred format (.mp3, .wav, .aiff, or whatever) and then throw them into the folder “add automatically to iTunes”.
was able to add as a new playlist, so that will work. THANK YOU.
