can't install effect plug-ins
Hi,
I’ve downloaded the 32-bit of both, extracted them, and pasted the .dll files under the Program files (86x)/plug-ins folder.
I open Audacity, go to effect/ add plug-ins, and in the window that opens I don’t see any news plug-ins that I can enable…
I’m using Audacity 2.2.2 and Windows 10.
Am I doing something wrong?
Thanks,
Oh, yes, the plugins: I tried adding Lisp and Spitfish, to no avail
The Audacity plugins folder recently moved from “Program files” to this hidden folder
C:\Users\<YourNameHere>\AppData\Roaming\audacity\Plug-Ins
awesome! problem solved, thank you so much!
