I recently bought Autotune, and have downloaded Audacity 2.1.1 to use it. When Enabling the VST Plugin in the Effects>Manage screen, I click on the VST, hit Enable, then press OK. However, when I try and search the Effects dropdown menu in Audacity for the newly enabled plugin, it isn’t there. I reopen the Effects>Manage screen, and despite the fact that I had enabled it about 30 seconds ago, the Autotune VST still shows up as 'New", rather than ‘Enabled’.
Things I’ve tried:
-Running Audacity as an Administrator
-Disabling the VST, then trying to Enable it from there. The plugin was then permanently Disabled.
-Deleted pluginregistry.cfg to try and refresh my list. It just took the Autotune VST’s status back to ‘New’
-Smashing my head into a wall
None of the above worked. Any help would be greatly appreciated. I know these aren’t the most active forums, but I could really use a hand. Cheers!
By the way, I downloaded the Installer, not the .zip.
