I’m trying to import an mp4 file so that I can extract the music from it (first time I’ve tried it). When I try to drag it in, I get an Error Importing message that says it is an Advanced Audio Coding file and that Audacity cannot open this type of file and to convert it to WAV or AIFF.
I’ve tried it with a few other mp4s with no joy.
I’ve installed the FFmpeg library. The version it says in my preferences is F(52.64.2),C(52.72.2),U(50.15.1).
If this is still a problem could you do a couple of things.
download MediaInfo (get the version without installer) from http://mediainfo.sourceforge.net/en/Download/Windows then open the video file in that. Click View > Text then you can copy and paste here what it says.
Copy and paste the log from Audacity at Help > Show Log… after failing to import the video.
14:49:59: File name is c:usershelenmusicmusicpossible sleep cd musictestbeep.m4a
14:49:59: Mime type is *
14:49:59: Opening with libav
14:49:59: Error: FFmpeg : avcodec_find_decoder() failed. Index[00], Codec[15002 - ]
14:49:59: Opening with libsndfile
14:49:59: Opening with liboggvorbis
14:49:59: Opening with libflac
14:49:59: Opening with lof
14:49:59: Error: Importer::Import: Opening failed.
