Cant find how to record in the middle of a song
the only way i can record a short fix at the end of a track is to go to the beginning of the song add new track and wait 5 minutes till i get to the end of the song and record the new info…if i try and record at 4:45 on the new track the record button gets greyed out when it is in play…how do i fix this?
I’ve run into this too it’s super frustrating. One workaround is to use Punch and Roll Recording under the Transport menu. You can also try setting a new Time Shift Tool section and then record directly at that point without playing the whole track. Hope that helps.
Great tips! Punch and Roll really makes editing smoother in tricky spots.
Thanks for the tip! I’ll definitely try Punch and Roll Recording next time.
