I found a bug when I can’t export audio to: “H:\Program Files (x86)\BIDIX\Wystawa 2025\Jak zrobić wystawe”, but I can into “H:\Program Files (x86)\BIDIX\Wystawa 2025” I suppose it’s because the first path has polish letters in it and the second one doesn’t. Program will just not do anything and I spend couple of minutes searching online why it’s not exporting before I just tried exporting into different path.
Hope this helps in fixing this bug. Thank you for creating an amazing software.
The Polish characters in the path name don’t seem to be the culprit here: I was able to export to a different directory, such as C:\temp\Jak zrobić wystawe, using the same string in Polish with no issues.
Apparently, you don’t have permissions to write to a system directory, which Program files (x86) is.
That’s odd because I exported it into “H:\Program Files (x86)\BIDIX\Wystawa 2025” with no problem. I don’t know why, program just didn’t do anything when I tried “H:\Program Files (x86)\BIDIX\Wystawa 2025\Jak zrobić wystawe”. I will try some more paths and let you guys know if the problem is present anywhere else.
I didn’t know what the restrictions are so I made a folder called Program Files (More) for special utility applications that I can’t install put in the normal Program Files folders.
I also don’t know if the restrictions are for security or just so you don’t accidently foul-up your applications, or both.
