I’m using Audacity 2.0.0 on Windows 7 x64 SP1 (Home Premium) . I haven’t had this problem before, but all of a sudden I cannot export as a WAV file. I tried using AIFF instead, but it didn’t work eaither. The error for the WAV file is;
“Error while writing WAV (Microsoft) file (disk full?). Libsndfile says…” Then it says a bunch weird accents, symbols and that box used when you don’t have the text (I’m assuming gibberish)
I can use FLAC, and just convert, but I’d really like to get to the root of the problem. I’ve tried re downloading, changing names and I do have HD space. Please, can anyone help me?
You may have run into the filename problem. Don’t put dates or other punctuation marks into your filenames. It can drive the computer nuts. Today is not 6/20/12, it’s 20120620. No slashes, no periods, no commas, etc.
That usually indicates that there is invalid metadata.
Go to “File menu > Open Metadata Editor”
Then click on the “Clear” button, then on the “OK” button.
Then try exporting.
