G-Snap was on new, I clicked enable, and then okay and nothing happened.
Then clicked disabled okay, then it disabled
then clicked enabled, okay, and still disabled.
Any idea on what to do?
What version of Audacity? All three numbers please, see the pink panel at the top of the page. Did you get it from http://audacityteam.org/download/windows?
GSnap is available here: http://www.gvst.co.uk/gsnap.htm. Make sure you get the 32-bit version of GSnap, even if you are on a 64-bit computer. GSnap should be enabled in Audacity 2.1.1 supplied by us.
