I just did a crude outline recording of me singing my new song on one track and my very humble (crappy ) attempt at playing the harmonica on a 2nd track.
But I forgot to use a metronome and my singing is a split second out on the last bar. I just need to add a split second of silence before the last phrase, but when I try to do it, it adds the silence to both tracks. And itâs only meant to be on the first vocal track.
How do I only select one track please? Or only paste to one track?
I did that thanks, but itâs still doing that to both tracks. The text you linked to says if you use the select tool and drag, it will only select one track, but it selects both tracks for me.
I know I could select only one track before in previous versions. I used to chop up songs all the time.
Is it possible I have the wrong default settings? I looked through all the menus but couldnât find anything that would suggest how to change it.
