Seemingly having issues with dragging tracks into Audacity. No other issues outside of Audacity. Having to import tracks manually using drop down menus at the top. Any help form the community would be most appreciated. I am a bit of an amateur. Have done a little googling on this subject with out much luck. OSX el capitan. Thanks in advance
It’s a bug. It’s been fixed in the development code so the next release will have the fix.
Alternatives: you can drag files to the Audacity icon in “Applications” or in the Dock, (or import the file from the menu as you are doing now).
