So, I have a problem. I need a wav file to be converted into 16 bit PCM wav, a program requires it. So, I loaded a 42-bit float wav into audacity, used export, and expected the output to be correct format. But no, it’s still 32-bit float. How to fix that?
I’m using windows 7, Audacity 2.1.0
How do you know that?
Audacity does not have Clip Info. If you’re waiting for Audacity to tell you about your sound file, you may have a long wait.
Media Info is available for Windows.
Get the program, not the installer.
In other words, when you import a file, Audacity defaults to expanding it to 32-bit float and that is what you are shown to left of the blue waves - the bit depth of the audio in the track, not the bit depth of the original file.
2.1.0 is old now. You can get the current 2.1.2 release here: http://www.audacityteam.org/download/windows.
