cannot use GSnap
My problem is that I cannot use GSnap(auto-tuning). I open an audio file, select part of all of it, and most of the effects are available except for GSnap and a few others. it worked once, but its not working now. I am REALLY frustrated. please help me
with my face twitching in irritation,
RATTLEGOAT
You have to enable effects (and press OK), before they appear in the effects list …
https ://manual.audacityteam.org/man/manage_effects_generators_and_analyzers.html
[ BTW GSnap is available in 32-bit & 64-bit
Currently Audacity can only use 32-bit plugins , (even if your machine is 64-bit) ].
I have made sure that Gsnap is enabled several times. it is not missing from the effect list, it is just grayed out.
The only way I can replicate that is if I still have another effect open when I try to use Gsnap.
Audacity does not permit two effects to be applied at the same time.
i just started a new project, selected a portion, but Gsnap is still grayed out.
