Cannot run Audacity on Ubuntu 20.04.6 LTS
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION=“Ubuntu 20.04.6 LTS”
I have tried to run Audacity in the following methods:
  1. Appimage:
./audacity-linux-3.5.0-x64.AppImage
/lib/x86_64-linux-gnu/libatk-1.0.so.0
/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0
/lib/x86_64-linux-gnu/libcairo-gobject.so.2
/lib/x86_64-linux-gnu/libcairo.so.2
/lib/x86_64-linux-gnu/libgio-2.0.so.0
/lib/x86_64-linux-gnu/libglib-2.0.so.0
/lib/x86_64-linux-gnu/libgmodule-2.0.so.0
/lib/x86_64-linux-gnu/libgobject-2.0.so.0
/lib/x86_64-linux-gnu/libgthread-2.0.so.0
/lib/x86_64-linux-gnu/libjack.so.0
/lib/x86_64-linux-gnu/libpixman-1.so.0
/lib/x86_64-linux-gnu/libportaudio.so
A notification box briefly starts up, disappears then hangs.
  1. Snap
snap run audacity
Testing for explicit PulseAudio choice…
Testing for ALSA permissions…
…and using ALSA.
(process:67089): Gdk-CRITICAL **: 17:43:30.762: IA__gdk_screen_get_root_window: assertion ‘GDK_IS_SCREEN (screen)’ failed
(process:67089): Gdk-CRITICAL **: 17:43:30.763: gdk_pixmap_new: assertion ‘(drawable != NULL) || (depth != -1)’ failed
/root/.conan/data/wxwidgets/3.1.3.1-audacity/
//build/7734eb24f4ac916341e253b3d41a393b492ce743/source_subfolder/src/gtk/bitma
p.cpp(827): assert ““IsOk()”” failed in ConvertToImage(): invalid bitmap
//build/7734eb24f4ac916341e253b3d41a393b492ce743/source_subfolder/src/common/im
age.cpp(2172): assert ““IsOk()”” failed in SetMaskColour(): invalid image
age.cpp(2223): assert ““IsOk()”” failed in SetMask(): invalid image
age.cpp(1853): assert ““IsOk()”” failed in GetWidth(): invalid image
age.cpp(1860): assert ““IsOk()”” failed in GetHeight(): invalid image
age.cpp(2112): assert ““IsOk()”” failed in GetAlpha(): invalid image
age.cpp(2232): assert ““IsOk()”” failed in HasMask(): invalid image
/_/build/7734eb24f4ac916341e253b3d41a393b492ce743/source_subfolder/src/common/im
age.cpp(1986): assert ““IsOk()”” failed in GetData(): invalid image
(process:67089): GdkPixbuf-CRITICAL **: 17:43:30.763: gdk_pixbuf_new_from_data: assertion ‘data != NULL’ failed
(process:67089): Gdk-CRITICAL **: 17:43:30.763: IA__gdk_screen_get_root_window: assertion ‘GDK_IS_SCREEN (screen)’ failed
(process:67089): Gdk-CRITICAL **: 17:43:30.763: IA__gdk_drawable_get_display: assertion ‘GDK_IS_DRAWABLE (drawable)’ failed
(process:67089): Gdk-CRITICAL **: 17:43:30.763: IA__gdk_cursor_new_from_pixbuf: assertion ‘GDK_IS_DISPLAY (display)’ failed
(process:67089): GLib-GObject-CRITICAL **: 17:43:30.763: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
Crash
  1. FlatPak
flatpak run org.audacityteam.Audacity
error: app/org.audacityteam.Audacity/x86_64/master not installed
  1. From Ubuntu
    /bin/audacity
    …/include/wx/font.h(261): assert "“pointSize == -1 || pointSize >= 0"” failed in ToFloatPointSize(): Invalid font point size
    17:46:11: Debug: ScreenToClient cannot work when toplevel window is not shown
    Trace/breakpoint trap (core dumped)
I cannot find any other way to get this program running. Aside from upgrading the OS, I am at a loss how to get this done.
Any suggestions are welcome.
Thanks
