I’ve looked through this forum front to back, and can’t find any information on problems installing Audacity 3.1.3 on Chromebook.
Any ideas on where I can go for some help?
Thanks
Thanks
Audacity does not officially support Chromebook.
However, apparently Chromebook is based on Linux and you can apparently enable Linux on some versions of Chromebook, and Audacity runs under many Linux installations.
Do a google search on running Audacity on Chromebook, or search this forum for Chromebook. You could also search the Chromebook forum for Audacity. ![]()
Audacity’s FAQ say basically the same as jademan wrote: https://manual.audacityteam.org/man/faq_about_audacity.html#Can_I_run_Audacity_on_a_Chromebook_laptop.3F
