Cannot compile Audacity 3.7.7 with ASIO support (Windows 10 x64)
Hello. By following the instructions found on the manual I can compile Audacity (using CMake 3.26.4 GUI and Visual Studio 2022 installed with the Desktop development with C++ workload), however, the built binary still lacks ASIO support. M̶i̶c̶r̶o̶s̶o̶f̶t̶ ̶C̶o̶p̶i̶l̶o̶t̶ ̶s̶u̶g̶g̶e̶s̶t̶s̶ ̶I̶’̶m̶ ̶“̶m̶i̶s̶s̶i̶n̶g̶ ̶t̶h̶e̶ ̶e̶n̶t̶i̶r̶e̶ ̶A̶u̶d̶a̶c̶i̶t̶y̶ ̶A̶S̶I̶O̶ ̶i̶n̶t̶e̶g̶r̶a̶t̶i̶o̶n̶ ̶l̶a̶y̶e̶r̶”̶ ̶a̶n̶d̶ ̶t̶h̶a̶t̶ ̶A̶u̶d̶a̶c̶i̶t̶y̶ ̶e̶x̶p̶e̶c̶t̶s̶:̶
̶l̶i̶b̶r̶a̶r̶i̶e̶s̶/̶l̶i̶b̶-̶a̶s̶i̶o̶/̶l̶i̶b̶r̶a̶r̶i̶e̶s̶/̶l̶i̶b̶-̶a̶s̶i̶o̶/̶C̶M̶a̶k̶e̶L̶i̶s̶t̶s̶.̶t̶x̶t̶l̶i̶b̶r̶a̶r̶i̶e̶s̶/̶l̶i̶b̶-̶a̶s̶i̶o̶/̶A̶S̶I̶O̶S̶D̶K̶2̶.̶3̶/̶
̶T̶h̶e̶ ̶t̶r̶o̶u̶b̶l̶e̶ ̶i̶s̶ ̶i̶t̶ ̶s̶e̶e̶m̶s̶ ̶n̶e̶i̶t̶h̶e̶r̶ ̶t̶h̶e̶ ̶G̶i̶t̶H̶u̶b̶ ̶r̶e̶p̶o̶s̶i̶t̶o̶r̶y̶ ̶n̶o̶r̶ ̶t̶h̶e̶ ̶z̶i̶p̶p̶e̶d̶ ̶s̶o̶u̶r̶c̶e̶ ̶c̶o̶d̶e̶ ̶c̶o̶n̶t̶a̶i̶n̶s̶ ̶t̶h̶e̶ ̶e̶x̶p̶e̶c̶t̶e̶d̶ ̶A̶S̶I̶O̶ ̶i̶n̶t̶e̶g̶r̶a̶t̶i̶o̶n̶ ̶l̶a̶y̶e̶r̶.̶
How, then, should Audacity be compiled with ASIO support?
Thank you.
Solved: all I had to do is check audacity_has_asio_support setting in the Configure step.
My simple 3 step method using the command line ( admin terminal) is as follows:-
Download:-
git clone -b release-3.7.7 --depth 1 https://github.com/audacity/audacity/ audacity3_7_7
pre-build :-
cmake -G "Visual Studio 17 2022" -DCMAKE_CONFIGURATION_TYPES=Release -Daudacity_has_asio_support=On -DAUDACITY_BUILD_LEVEL=2  -S D:\audacity3_7_7 -B d:\audacity3-7-7
Finally open
ALL_BUILD.vcxproj
in Visual Studio and build.
