Cannot change volume in increments
I am running version 3.7.3 on Arch Linux / CachyOS. I am not able to adjust the volume in increments. I was able to adjust the volume prior to Monday 3/17. Please note I was running EndeavorOS & I switched to running CachyOS. That was the only difference on my end. Not sure if it’s the OS or there was a small update. I am only able to adjust as whole values instead of .5 or others. It will let me try put the value for example -8.5 & I hit enter. If I check the volume, it just stays at -8. I can only move the slider to whole numbers.
