I have Ubuntu 22.04 LTS (dual boot with Windows 11 which I rarely use), and am not a programmer or systems expert.
I was running snap Audacity a few years ago, but I just retried it and could not get any sound from either speaker or headphones.
I completely uninstalled Audacity and reinstalled version 3.7.9 via snap. When I launched it, it suggested running the command “sudo snap connect audacity:alsa”, which I did.
Now I can read and edit audio files from my Ubuntu partitions (ext4), but when I try to open a file residing on my NTFS partition, it says “Permission denied”.
I don’t have Windows 11, thank goodness, but ChatGPT suggests disabling Fast Startup because this can leave NTFS partitions in a partially hibernated state. That would be the first thing to try.
Thanks Mark, but in principle that is not the problem. Fast Startup is disabled in BIOS, and this problem is occurring only with this particular installation of Audacity.
Sorry Mark, “Fast Startup” (and “Hibernation” which is necessary to make it work) are both disabled in my Windows 11. I was confusing with “Secure Boot” which can also cause trouble and is disabled in BIOS.
Although I use Mint rather than Ubuntu and Windows 10, I don’t recall ever having to edit fstab. Maybe it’s something peculiar to Windows 11. I am stumped at the moment but if inspiration strikes I will let you know.
When I first installed Ubuntu 22.04 four years ago, I had to carefully edit fstab to solve some permission issues for NTFS (less serious than the present ones).
My hunch that there is a bug in this particular Audacity version in the context of my particular configuration. If I don’t hear back from you or a colleague within a couple of weeks, I will submit a bug report to Audacity.
If the problem is unsolved but goes away when I update to Ubuntu 26.04 LTS in a few months (and/or after trying Audacity 4), I will inform Audacity and also the Forum. All of this in the spirit of open source development, since the issue is not critical for me given my occasional use of Audacity (now that I know, I can easily work on ext4 partitions and copy my results to NTFS as needed) (-:
