can you view multiple tracks simultaneous
Veer.2.0.5. Windows XP
PROBLEM: selected 10 wav tracks from unfinalized CD developed from recordings using a Tascam 2488neo recorder. The tracks are synchronized. I want to view all 10 tracks after editing, on screen. I want to mix the tracks and save the master. Can this be done?
If you don’t want to scroll up and down, try View > Fit Vertically.
File > Export… does the mix to a stereo or mono file.
Export to WAV if you want to burn the recordings to a CD. See Burning music files to a CD - Audacity Manual .
If you prefer to see what the exported file will look like before you export, use Tracks > Mix and Render to mix the 10 tracks to one.
Please be careful with Windows XP. Microsoft are no longer officially supporting it, so it will be unpatched against any new security vulnerabilities that appear.
Make sure you have XP Service Pack 3. You can still download Service Pack 3 from Microsoft if necessary: http://support.microsoft.com/kb/322389/en-gb .
Ensure you have a good third-party anti-virus application. Be aware though that this will not give you complete protection against a previously unknown attack.
For some extra protection you can install http://technet.microsoft.com/en-us/security/jj653751 .
If it is not practicable for you to update to the much more secure Windows 7 or Windows 8, you can consider installing a Linux operating system instead. Most versions are free and all are very secure.
