Hi,
Timeline is a nice feature, but I don’t want to move the entire track. I only want to move a portion of the track.
Is that possible? If so, how?
Thanks,
Jeff
Hi,
Thanks,
Jeff
To move part of an audio track, you need to split the track so that the part that you want to move is a separate audio clip.
Example:
If you have a 30 second track and you want to move the portion “20 to 30 seconds” so that it is at “25 to 35 seconds”, then:
Note that audio clips cannot overlap on the same track, so if you need overlapping audio clips then they must be on separate tracks. In this case you can:
