Can only move cursor in one second intervals [SOLVED]
Hi all,
I just updated to Audacity 2.4.2 (don’t know which version I had before) and noticed that I now can only position the cursor at full second intervals. There seems to be no fine grain control to position the cursor anywhere else between full seconds.
Where can I change this odd behavior? I found nothing in the preferences or anywhere else.
Thanks for your help!
Set “Snap to:” to “Off” (near the bottom of the main Audacity window.
More info about “Snap to:” https://manual.audacityteam.org/man/selection_toolbar.html#snap
Thank you very much :smiley:
