Can no longer export labels
I used to select all …export… export labels then choose the amount of seconds and it would split the songs into 10 second wav files… …now both export labels and export midi are greyed out… what happened?
Labels and MIDI now can be exported via File → Export Other.
Hello there… that was what was greyed out… I found it again under TOOLS … regular interval labels…
