Hi
can i download a older verision?
for example audacity-win-2.1.2
thanks
Hi
thanks
Yes, from here: http://www.oldfoss.com/Audacity.html but why would you want to?
hi
just because it doesn’t work under w7 clean install without all the updates
it gives me this error audacity api-ms-win-crt-runtime-l1-1-0.dll is missing
and seeing i use on several computer ,many of them are not connected to internet and on many of them i can not install updates or program
i can not use it
thanks
