Can Audacity remove human vocal from music?
Can Audacity remove human vocal from music like AudioDirector?
Thanks & regards,
Lee
Yes, but you need a plugin for it: Audacity ® | Introducing OpenVINO AI effects for Audacity
Thank you. Glad to see Audacity has this function.
I downloaded both zip files ( Audacity-OpenVINO-Module-3.4.2-R1.zip, openvino-models.zip), unzip them, and copy both unzipped folders to C:\Program Files\Audacity\ . I then reboot Windows (just in case). However my Windows Audacity ver. 3.4.2 does not show “mod-openvino” under 'Edit → ‘Preferences’ → ‘Modules’
Hope next Audacity release could include this function so we don’t have to manually integrate it.
Hmm, did you follow along to installation video? One way to double check – After extracting zip files, you should see mod-openvino.dll in C:\Program Files\Audacity\modules.
By “You can check vocal reduction and isolation plugin”, do you mean I can download the plugin somewhere and add the plugin in Audacity?
Thanks & regards.
Thanks & regards.
You might also be interested in taking a look at moises ai. It does a great job separating stems. It allows 5 free uses each month or you can consider buying full access. I believe it was a very reasonable price point.
Thank you for the info. I’ll give it a try.
Well this is down right cool, and integrated into Audacity. Thanks Team for all that you do for those of us that can’t. :grin:
