Can anyone recommend a Windows tablet for Audacity?
I do a radio show/podcast and want to record on Audacity using a tablet. I can’t use Mac for my purpose (I use one at home) so I need to explore Windows. I need something I can talk into, whether by mic or direct, import MP3 from Internet then transfer MP3 to my Mac. The reason I want a tablet is that I need something as light as possible to take on holidays. I know other formats are better quality than MP3 for a lot of applications and in most peoples opinions. TIA. Rob
I don’t have any recommendations for tablets, but for “field recording” there are many good and extremely portable audio recorders (I use a Zoom H2). These usually record to a flash card, which can easily be copied over to a computer for editing.
Note that “field recorders” are very different from the old “dictaphones” in that they are designed for high quality audio.
There’s a huge range of field recorders available from Zoom, Tascam, Sound Devices, and others.
At the cheap end: Zoom H1essential (under $100)
At the expensive end: Sound Devices MixPre-10 II (around $1500)
Can you please explain this sentence?
The other point is: Tablets usually are iOS devices or Android devices. Since the Windows Phone is dead for some years now - are there any Windows tablets at all?
And no, as far as I know there is no Audacity for phones or tablets, not for iOS and not for Android.
I’ve been saying this a lot lately. Buy a audio field recorder. You can spend as much or as little as you want depending on the features you want. They are almost certainly less expensive than a good tablet. You can still edit with Audacity later.
Here is a group test of Windows ‘tablets’: Best Windows tablets of 2026
If you don’t need to record voice, download YouTube content , edit etc all on the same device whilst on holiday, I’d second the field recorder idea. I use a Tascam DR-05XP and that’s pretty good. You can record on that and copy to your desktop later. It is WAY cheaper than a Windows tablet.
Thanks Rex. I’ve got an Audio Field Recorder but unfortunately it doesn’t do the whole of the job in hand. Thanks anyway Rob
Thanks evil MRB I’ve got an Audio Field Recorder but unfortunately it doesn’t do the full job in hand. I’ve looked at the reviews but just wondered if anyone had any experiences. Cheers Rob
Thanks romontschun. My MacBook is heavy and when I go abroad I usually take under seat luggage. There are Windows tablets, like Asus do one. The fact that Audacity is Windows or MacOS and Apple tablets are IOS means I have to look at Windows option. Cheers Rob
Thanks Steve Unfortunately feels recorders are not an option for my usage. Thanks anyway
FWIW: I’ve been working on porting Audacity 4 to the browser:
It’s not yet done, but that may make your choice of tablet somewhat easier as browser stuff should run practically everywhere
@LeoWattenberg Mh, the website of your project appears to be broken… I have tried 4 (Safari, Firefox, Google Chrome and Opera) browsers on macOS Sonoma and on macOS Tahoe - but I cannot see anything. For a short moment, some text appears, but then the page becomes solid white only (in Opera, it becomes black instead at night).
aye, it’s nowhere near stable yet unfortunately. Should get back tomorrow or so.
For nearly 8 years I used my Microsoft Surface Pro 3 for my podcast. I used it conjunction with my Zoom H5, but I could record directly to the Surface and have on occasion. You might need to buy USB mic for it. Since it is a Windows based tablet, Audacity will run fine on it. The only issue I can find is the expense. They are a tad on the pricey side. I liked the Surface so much, I upgraded to a Surface pro Laptop. It’s some good stuff. Highly recommended.
Thank you VERY much.
