[C#] FFT Implementation
Hi,
I’m having some issues calculating intensity from floating point samples obtained via an API in C# since I do not know if my implementation of FFT is correct.
Here is my main class and the FFT class I found on the internet:
test.cs (The main application class + method): http://pastebin.com/zKrpnsL6
FFT.cs (FFT class found on the net): http://pastebin.com/L3Na4Xuy
Edit: reader.Read(buffer, 0, 4096); this line reads 4096 floating point samples into the buffer. All help is appreciated guys!
Anyhow, I could really use some indication / help from you guys.
Thanks!
Well, don’t know if this code will help you, if not, I don’t know what else to offer.
// Code to implement decently performing FFT for complex and real valued
// signals. See www.lomont.org for a derivation of the relevant algorithms
// from first principles. Copyright Chris Lomont 2010-2012.
// This code and any ports are free for all to use for any reason as long
// as this header is left in place.
// Version 1.1, Sept 2011
using System;
/* History:
 * Sep 2011 - v1.1 - added parameters to support various sign conventions
 *                   set via properties A and B.
 *                 - Removed dependencies on LINQ and generic collections.
 *                 - Added unit tests for the new properties.
 *                 - Switched UnitTest to static.
 * Jan 2010 - v1.0 - Initial release
namespace Lomont
    /// <summary>
    /// Represent a class that performs real or complex valued Fast Fourier
    /// Transforms. Instantiate it and use the FFT or TableFFT methods to
    /// compute complex to complex FFTs. Use FFTReal for real to complex
    /// FFTs which are much faster than standard complex to complex FFTs.
    /// Properties A and B allow selecting various FFT sign and scaling
    /// conventions.
    /// </summary>
    public class LomontFFT
        /// <summary>
        /// Compute the forward or inverse Fourier Transform of data, with
        /// data containing complex valued data as alternating real and
        /// imaginary parts. The length must be a power of 2. The data is
        /// modified in place.
        /// </summary>
        /// <param name="data">The complex data stored as alternating real
        /// and imaginary parts</param>
        /// <param name="forward">true for a forward transform, false for
        /// inverse transform</param>
        public void FFT(double[] data, bool forward)
            var n = data.Length;
            // checks n is a power of 2 in 2's complement format
            if ((n & (n - 1)) != 0)
                throw new ArgumentException(
                    "data length " + n + " in FFT is not a power of 2");
            n /= 2;    // n is the number of samples
            Reverse(data, n); // bit index data reversal
            // do transform: so single point transforms, then doubles, etc.
            double sign = forward ? B : -B;
            var mmax = 1;
            while (n > mmax)
                var istep = 2 * mmax;
                var theta = sign * Math.PI / mmax;
                double wr = 1, wi = 0;
                var wpr = Math.Cos(theta);
                var wpi = Math.Sin(theta);
                for (var m = 0; m < istep; m += 2)
                    for (var k = m; k < 2 * n; k += 2 * istep)
                        var j = k + istep;
                        var tempr = wr * data[j] - wi * data[j + 1];
                        var tempi = wi * data[j] + wr * data[j + 1];
                        data[j] = data[k] - tempr;
                        data[j + 1] = data[k + 1] - tempi;
                        data[k] = data[k] + tempr;
                        data[k + 1] = data[k + 1] + tempi;
                    var t = wr; // trig recurrence
                    wr = wr * wpr - wi * wpi;
                    wi = wi * wpr + t * wpi;
                mmax = istep;
            // perform data scaling as needed
            Scale(data,n, forward);
        /// <summary>
        /// Compute the forward or inverse Fourier Transform of data, with data
        /// containing complex valued data as alternating real and imaginary
        /// parts. The length must be a power of 2. This method caches values
        /// and should be slightly faster on than the FFT method for repeated uses.
        /// It is also slightly more accurate. Data is transformed in place.
        /// </summary>
        public void TableFFT(double[] data, bool forward)
            // make table if needed
            if ((cosTable == null) || (cosTable.Length != n))
                Initialize(n);
            var mmax = 1;
            var tptr = 0;
            while (n > mmax)
                    var wr = cosTable[tptr];
                    var wi = sign * sinTable[tptr++];
                        var j = k + istep;
                mmax = istep;
            Scale(data, n, forward);
        /// <summary>
        /// data containing real valued data only. The output is complex
        /// valued after the first two entries, stored in alternating real
        /// and imaginary parts. The first two returned entries are the real
        /// parts of the first and last value from the conjugate symmetric
        /// output, which are necessarily real. The length must be a power
        /// of 2.
        /// </summary>
        public void RealFFT(double[] data, bool forward)
            var n = data.Length; // # of real inputs, 1/2 the complex length
            var sign = -1.0; // assume inverse FFT, this controls how algebra below works
            if (forward)
            { // do packed FFT. This can be changed to FFT to save memory
                TableFFT(data, true);
                sign = 1.0;
                // scaling - divide by scaling for N/2, then mult by scaling for N
                if (A != 1)
                    var scale = Math.Pow(2.0, (A - 1) / 2.0);
                    for (var i = 0; i < data.Length; ++i)
                        data[i] *= scale;
            var theta = B * sign * 2 * Math.PI / n;
            var wjr = wpr;
            var wji = wpi;
            for (var j = 1; j <= n/4; ++j)
                var k = n / 2 - j;
                var tkr = data[2 * k];    // real and imaginary parts of t_k  = t_(n/2 - j)
                var tki = data[2 * k + 1];
                var tjr = data[2 * j];    // real and imaginary parts of t_j
                var tji = data[2 * j + 1];
                var a = (tjr - tkr) * wji;
                var b = (tji + tki) * wjr;
                var c = (tjr - tkr) * wjr;
                var d = (tji + tki) * wji;
                var e = (tjr + tkr);
                var f = (tji - tki);
                // compute entry y[j]
                data[2 * j] = 0.5 * (e + sign * (a + b));
                data[2 * j + 1] = 0.5 * (f + sign * (d - c));
                // compute entry y[k]
                data[2 * k] = 0.5 * (e - sign * (b + a));
                data[2 * k + 1] = 0.5 * (sign * (d - c) - f);
                var temp = wjr;
                // todo - allow more accurate version here? make option?
                wjr = wjr * wpr - wji * wpi;
                wji = temp * wpi + wji * wpr;
            if (forward)
                // compute final y0 and y_{N/2}, store in data[0], data[1]
                var temp = data[0];
                data[0] += data[1];
                data[1] = temp - data[1];
            else
                var temp = data[0]; // unpack the y0 and y_{N/2}, then invert FFT
                data[0] = 0.5 * (temp + data[1]);
                data[1] = 0.5 * (temp - data[1]);
                // do packed inverse (table based) FFT. This can be changed to regular inverse FFT to save memory
                TableFFT(data, false);
                // scaling - divide by scaling for N, then mult by scaling for N/2
                //if (A != -1) // todo - off by factor of 2? this works, but something seems weird
                    var scale = Math.Pow(2.0, -(A + 1) / 2.0)*2;
                        data[i] *= scale;
        /// <summary>
        /// Determine how scaling works on the forward and inverse transforms.
        /// For size N=2^n transforms, the forward transform gets divided by
        /// N^((1-a)/2) and the inverse gets divided by N^((1+a)/2). Common
        /// values for (A,B) are
        ///     ( 0, 1)  - default
        ///     (-1, 1)  - data processing
        ///     ( 1,-1)  - signal processing
        /// Usual values for A are 1, 0, or -1
        /// </summary>
        public int A { get; set; }
        /// <summary>
        /// Determine how phase works on the forward and inverse transforms.
        /// For size N=2^n transforms, the forward transform uses an
        /// exp(B*2*pi/N) term and the inverse uses an exp(-B*2*pi/N) term.
        /// Common values for (A,B) are
        /// Abs(B) should be relatively prime to N.
        /// Setting B=-1 effectively corresponds to conjugating both input and
        /// output data.
        /// Usual values for B are 1 or -1.
        /// </summary>
        public int B { get; set; }
        public LomontFFT()
            A = 0;
            B = 1;
        #region Internals
        /// <summary>
        /// Scale data using n samples for forward and inverse transforms as needed
        /// </summary>
        /// <param name="data"></param>
        /// <param name="n"></param>
        /// <param name="forward"></param>
        void Scale(double[] data, int n, bool forward)
            // forward scaling if needed
            if ((forward) && (A != 1))
                var scale = Math.Pow(n, (A - 1) / 2.0);
                    data[i] *= scale;
            // inverse scaling if needed
            if ((!forward) && (A != -1))
                var scale = Math.Pow(n, -(A + 1) / 2.0);
                    data[i] *= scale;
        /// <summary>
        /// Call this with the size before using the TableFFT version
        /// Fills in tables for speed. Done automatically in TableFFT
        /// </summary>
        /// <param name="size">The size of the FFT in samples</param>
        void Initialize(int size)
            // NOTE: if you port to non garbage collected languages
            // like C# or Java be sure to free these correctly
            cosTable = new double[size];
            sinTable = new double[size];
            // forward pass
            var n = size;
            int mmax = 1, pos = 0;
            while (n > mmax)
                var theta = Math.PI / mmax;
                // compute in a slightly slower yet more accurate manner
                var wpr = Math.Sin(theta / 2);
                wpr = -2 * wpr * wpr;
                    cosTable[pos] = wr;
                    sinTable[pos++] = wi;
                    var t = wr;
                    wr = wr * wpr - wi * wpi + wr;
                    wi = wi * wpr + t * wpi + wi;
                mmax = istep;
        /// <summary>
        /// Swap data indices whenever index i has binary
        /// digits reversed from index j, where data is
        /// two doubles per index.
        /// </summary>
        static void Reverse(double [] data, int n)
            // bit reverse the indices. This is exercise 5 in section
            // 7.2.1.1 of Knuth's TAOCP the idea is a binary counter
            // in k and one with bits reversed in j
            int j = 0, k = 0; // Knuth R1: initialize
            var top = n / 2;  // this is Knuth's 2^(n-1)
            while (true)
                // Knuth R2: swap - swap j+1 and k+2^(n-1), 2 entries each
                var t = data[j + 2];
                data[j + 2] = data[k + n];
                data[k + n] = t;
                t = data[j + 3];
                data[j + 3] = data[k + n + 1];
                data[k + n + 1] = t;
                if (j > k)
                { // swap two more
                    // j and k
                    t = data[j];
                    data[j] = data[k];
                    data[k] = t;
                    t = data[j + 1];
                    data[j + 1] = data[k + 1];
                    data[k + 1] = t;
                    // j + top + 1 and k+top + 1
                    t = data[j + n + 2];
                    data[j + n + 2] = data[k + n + 2];
                    data[k + n + 2] = t;
                    t = data[j + n + 3];
                    data[j + n + 3] = data[k + n + 3];
                    data[k + n + 3] = t;
                // Knuth R3: advance k
                k += 4;
                if (k >= n)
                    break;
                // Knuth R4: advance j
                var h = top;
                while (j >= h)
                    j -= h;
                    h /= 2;
                j += h;
            } // bit reverse loop
        /// <summary>
        /// Pre-computed sine/cosine tables for speed
        /// </summary>
        double [] cosTable;
        double [] sinTable;
        #endregion
// end of file
Best Regards, David
