burn cd with music/narration/special effects
Can you, or how do you burn a cd with a WAV file which contains music and narration and special effects?
I’m using Audacity 2.1.1, .exe installer with Windows 7.
Audacity does not burn CDs. You need a CD burning program to do that, such as CDburnerXP, or Nero, or even iTunes.
You can use Audacity to [u]mix[/u] music, narration, sound effects, etc. Then, export to a WAV file (or multiple WAV files) and you copy your final production to a CD with your CD burning software.
But don’t lose all your original clips and segments. Once you mix down to a single show, you can’t unmix it.
That’s if you want a Data CD. Data CDs are little flat hard drives. You can put any files on there you want, but older music CD players may not know what to do with a DATA CD even if it has music on it.
You can use your burner program to create an Audio CD. That is a real thing and those will play on any music player.
