They would be created when you ran Audacity (with mod-script-pipe) as root. (user id for root is 0)
These are not normal files, they are named fifo pipes.
When you launched Audacity as root, did you not see an error / warning:
Audacity could not find a place to store temporary files.
Please enter an appropriate directory in the preferences dialog.
No, I didn’t see this warning even though the files were not owned by root. After launching as roo, when I checked the owner in /tmp, it was changed BACK to root (I assume by the program).
From /home/pi, I have cloned the latest repos of wxWidgets and Audacity. Then:
cp -r wxWidgets wxWidgets-dev
cd wxWidgets-dev
git reset --hard 721d62a //this is the tag for the latest wxWidgets 3.0.4 release
./configure --with-gtk
./make -j3 //the -j3 tag uses three cores (don't want to get too hot ;-))
cd ..
cp -r audacity audacity-dev
cd audacity-dev
git reset --hard 2fef7f3 //this is the tag for the latest Audacity 2.1.3 release
./configure <options> //including specifying WX_CONFIG=/home/pi/wxwidgets-dev/wx-config
cd ./lib-src/mod-script-pipe/
make -j3
cd ..
make -j3
sudo make install
cd ..
mkdir .audacity-files
cd .audacity-files
mkdir modules
cd modules
cp ../../audacity-dev/modules/mod-script-pip.so ./
After executing Audacity as the nonprivileged user, the modules dialog can’t find mod-script-pipe.
OK, so I’ve tried building and installing 2fef7f3, but with wxWidgets 3.0.2 and on a laptop rather than a Pi, and mod-script-pipe works fine for me.
I’m running out of ideas, short of scrubbing the system and starting again from scratch.
$ cd .audacity-files/
$ ls -al
total 12
drwxr-xr-x 3 pi pi 4096 Mar 20 21:39 .
drwxr-xr-x 35 pi pi 4096 Mar 21 23:15 ..
drwxr-xr-x 2 pi pi 4096 Mar 20 21:39 modules
$ cd modules/
$ ls -al
total 48
drwxr-xr-x 2 pi pi 4096 Mar 20 21:39 .
drwxr-xr-x 3 pi pi 4096 Mar 20 21:39 ..
-rwxr-xr-x 1 pi pi 40552 Mar 20 21:39 mod-script-pipe.so
I started with a fresh copy of Raspbian Stretch 2018-03-13, then built wxwidgets 3.0.4 and Audacity 2.2.2, and voila - everything works, including the ability to load mod-script-pipe.so. The location of the file is the standard user location .audacity-files/modules/.
So the bottom line is that my first attempt must’ve had something wonky with it. I’m closing this thread with a complete list of the commands I needed to build Audacity in Raspbian:
sudo apt-get install libgtk-3-dev
sudo apt-get install cmake
sudo apt-get install libasound2-dev
<Github configuration and SSH cert>
cd ~
git clone https://github.com/wxwidgets/wxwidgets
git clone https://github.com/audacity/audacity
cp -r wxwidgets wxwidgets-dev
cd wxwidgets-dev
./configure --with-gtk --enable-debug
./make -j3
cd ..
cd audacity-dev
git reset --hard f665e6d
./configure CXXFLAGS="-std=gnu++11" WX_CONFIG=/home/pi/wxwidgets-dev/wx-config --with-lame --with-vorbis=local --with-libid3tag --with-libsoxr=local --with-libvorbis --with-lv2 --with-portaudio --with-midi --with-portmidi --with-widgetextra=local --with-portmixer --without-nyquist --disable-sse
make -j3
cd ../..
make -j3
cd ..
cd .audacity-files
mkdir modules
cd modules
