Bug Report
Hello, I have been trying to add plugins to Audacity 2.2.2 Portable and been having the hardest time on getting the LV2 plugins to work on Audacity. They finally loaded when I placed the LV2 folder in %appdata%\Roaming\ but Audacity won’t load the plugin when I click on it, I get this “Couldn’t instantiate effect” message. I’m also wondering where I can put the LV2 folder on my flashdrive so that Audacity Portable will load them from the flashdrive.
I am also wondering, because I just joined this forum, where do you submit bug reports? I’m still learning how this all works.
Much Appreciation.
Audacity_dbgrpt-1292-20180501T151057.zip (104 KB)
If you are referring to the “Portable Apps” version of Audacity (Audacity Portable (audio editor and recorder) | PortableApps.com), then support and bug reports should go to their site.
