Version 3.7.7/Windows. “Sample Rate” has been added to the Export Audio dialog, which I am VERY^1000 happy with. It doesn’t seem to work properly when batch exporting using macros. If I do a manual export, and change “Bit Depth”, that new bit depth will be used the next time I export using a macro. Would be nice with some parameters on the Export-command, but it works. Now, if I do a manual export, and change “Sample Rate”, that new sample rate will NOT be used, the next time I export using a macro. The sample rate used is the one in Preferences - Audio Settings - Project sample rate. It defaults to 48K, but I always export/convert to 44.1. I can just change the default in Settings, but it would be nice (and more correct imo) if it used the setting from my last manual export, as it does with “Bit Depth”. “Sample Rate” was added to the Export dialog pretty recently, so I assume you just forgot the macro functionality. Not super important, but I hope you will look into it at some time. Thank you.
The exporter for macros is somewhat broken, yes. The team is currently working on a new solution for Audacity 4, which should fix that
Will look forward to it. Thanks for a quick response.
