Bug / Error - OpenVino 5.2R2 & Audacity 5.1 - Won't open
Hi,
I installed Audacity 5.1 and OpenVino 5.2R2.
When I go to transcribe I get the following error:
15:42:24: Audacity 3.5.1
15:42:24: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
15:42:24: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
15:42:24: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
15:42:24: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
15:42:24: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
15:42:31: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
15:42:31: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
15:42:31: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
15:42:31: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
15:42:31: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
15:42:38: Loaded 72 string 2.474609 Kb in size
15:42:38: Project loaded in 130 ms
15:43:08: Operation ‘Pre-processing’ took 0.000000 seconds. Poll was called 0 times and took 0.000000 seconds. Yield was called 0 times and took 0.000000 seconds.
15:43:12: Error: In Whisper Transcription Effect, exception: invalid map<K, T> key
15:43:20: Operation ‘OpenVINO Whisper Transcription’ took 3.875000 seconds. Poll was called 247 times and took 0.100867 seconds. Yield was called 40 times and took 0.039453 seconds
My PC is an up to date Win 10 with an i7-3770K processor & 16GB Ram. No graphics card. Running Win Pro.
I could see an issue have no graphics but I understood VinoAI was using the CPU.
Any help Audacity?
Hi @Alsone,
I have a system that I have been able to reproduce this. I will take a look later today, to see if I can root cause the issue… so I don’t have any fix or suggested workarounds yet.
By the way, we’re tracking this issue here: Transcript fails 3.5.1-R2 · Issue #143 · intel/openvino-plugins-ai-audacity · GitHub
Thanks,
Ryan
Many thanks Ryan much appreciated. Would happen just as I have some very important audio to transcribe!!!
Sure you’ll fix it though, I’m just hoping quickly.
BTW not sure if this is another bug, but I alos tried to install FFmpg. When I went to modules etc I found Lame was already loaded according to a header but there was none of the loading dialogue or buttons from which to load FFmpg. Another bug or somehow auto loaded?
Just to add another one on Ryan that might be related, when you open 5.1 and the App starts it puts a pop through the speakers a bit like static.
Hi @Alsone,
Sorry for late reply. Just to note that a fix for the transcribe issue is available in this plugin release: Release v3.5.1-R2.1 · intel/openvino-plugins-ai-audacity · GitHub
Also, just wanted to point out that the last couple of issue that you mention in this thread (FFMPeg / lame / dialogue buttons, static pop) are unrelated to the AI plugins. You may want to get help / report those issues here: Issues · audacity/audacity · GitHub
Ok thanks Ryan.
