I’m using Manjaro Linux, Audacity 2.3.2 installed from community repository through pamac.
Playback only plays briefly (a fraction of a second) and then stops. Dragging the white arrows to match the entire track makes no difference. The sound that does play comes out my headphones normally.
Are you the same person as this post, or is this just a weird coincidence? https://forum.audacityteam.org/t/opening-audacity-lags-out-microphone-until-reboot/53429/15
Nope, not me.
Quite a coincidence then. Just checking that I’m not repeating myself.
What output do you get from the command:
pacmd list-modules
24 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "12.2"
index: 1
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="1" name="pci-0000_1c_00.1" card_name="alsa_card.pci-0000_1c_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
module.description = "ALSA Card"
index: 7
argument: <device_id="0" name="usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00" card_name="alsa_card.usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
index: 8
argument: <device_id="2" name="pci-0000_1e_00.3" card_name="alsa_card.pci-0000_1e_00.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
index: 9
argument: <>
used: -1
load once: yes
properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
index: 10
argument: <>
used: -1
load once: no
properties:
module.description = "ESOUND protocol (UNIX sockets)"
index: 12
argument: <>
used: -1
load once: yes
properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 14
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
index: 15
argument: <>
used: -1
load once: yes
properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
index: 16
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 21
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 22
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 23
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 25
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
That all looks normal to me.
Please post the “Audio device info” from Audacity (See: https://manual.audacityteam.org/man/help_menu_diagnostics.html)
Default recording device number: 12
Default playback device number: 12
Device ID: 0
Device name: HDA ATI HDMI: 0 (hw:0,3)
Host name: ALSA
Recording channels: 0
Playback channels: 2
Low Recording Latency: -1
Low Playback Latency: 0.00580499
High Recording Latency: -1
High Playback Latency: 0.0348299
Supported Rates:
32000
44100
48000
Device ID: 1
Device name: HDA ATI HDMI: 1 (hw:0,7)
Host name: ALSA
Playback channels: 8
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 2
Device name: HDA ATI HDMI: 2 (hw:0,8)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 3
Device name: HDA ATI HDMI: 3 (hw:0,9)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 4
Device name: HDA ATI HDMI: 4 (hw:0,10)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 5
Device name: HDA ATI HDMI: 5 (hw:0,11)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 6
Device name: HD-Audio Generic: ALC892 Analog (hw:1,0)
Host name: ALSA
Recording channels: 2
Playback channels: 6
Low Recording Latency: 0.00580499
High Recording Latency: 0.0348299
Supported Rates:
44100
48000
96000
192000
Device ID: 7
Device name: HD-Audio Generic: ALC892 Digital (hw:1,1)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
192000
Device ID: 8
Device name: HD-Audio Generic: ALC892 Alt Analog (hw:1,2)
Host name: ALSA
Playback channels: 0
Low Playback Latency: -1
High Playback Latency: -1
Supported Rates:
Device ID: 9
Device name: HyperX Virtual Surround Sound: USB Audio (hw:2,0)
Host name: ALSA
Low Recording Latency: 0.00868481
Low Playback Latency: 0.00868481
Supported Rates:
8000
16000
24000
32000
44100
48000
Device ID: 10
Device name: hdmi
Host name: ALSA
Supported Rates:
32000
44100
48000
Device ID: 11
Device name: pulse
Host name: ALSA
Recording channels: 32
Playback channels: 32
High Recording Latency: 0.0348073
High Playback Latency: 0.0348073
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 12
Device name: default
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Selected recording device: 12 - default
Selected playback device: 12 - default
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
Available recording sources:
Available playback volumes:
Recording volume is emulated
Playback volume is emulated
How are your headphones connected to the computer?
What is your default recording device?
Headphones are connected via USB 3.0. Default recording device is a Blue Snowball iCE. Also, seems loading in regular audio files has the same effect.
Works now.
