I am having an issue with Audacity 2.1.0, Windows 7.
I have been recording into Audacity this morning using a Bluetooth device as the input source. I was able to make several recordings and listen to the audio without any problems. However, in an attempt to make additional recordings in a new session with said Bluetooth source, the cursor doesn’t move left to right. It just remains at the “0:00” mark while flickering. I stop the recording and no audio is present. I get the following message:
“Latency Correction setting has caused the recorded audio to be hidden before zero…” etc.
If I change my input source to anything other than the Bluetooth source and begin recording, the cursor moves left to right normally (even though I don’t have any other input connected). If I switch the input source back to Bluetooth, the issue remains. There are no other tracks recorded in this session. It is a brand new session!
I’ve tried restarting Audacity, and I have turned my computer off and back on again. I have checked the “overdub” setting in Audacity (even though there is nothing recorded in the session, so I am not looking to overdub). I’ve tried looking this issue up in the Audacity Forum, but all I have seen so far are instances of other users not being able to record when using a USB input device, not Bluetooth. And I have also seen the suggestion to “cold boot” the computer (whatever that means), but when I click on the Start menu, I don’t see a Power button/menu, but I see the option to Shutdown. (I’ve tried holding down the SHIFT button while powering down the computer, but it appears this is not the same thing. At least, it hasn’t resolved my issue.) I’ve tried searching for instructions on “How to Cold Boot a Windows 7 PC”, but my search comes back with either "How to cleanboot" or links describing problems with a Windows 7 cold boot.
I hope to have provided all the necessary info in my post. Any assistance would be greatly appreciated!
Regards.
