BlueScreen/SideBySide error on Win7 (not even using Audacity)
Win 7 Pro (SP1)
Audacity 2.2.0
I have not used Audacity in ages.
Been getting random reboots.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional information about the problem:
BCCode: 1a
BCP1: 0000000000041790
BCP2: FFFFFA8001700EE0
BCP3: 000000000000FFFF
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Checked Event Viewer this time.
Activation context generation failed for “C:\Program Files (x86)\Audacity\audacity.exe”.Error in manifest or policy file “” on line . A component version required by the application conflicts with another component version already active. Conflicting components are:. Component 1: C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24483_none_e372d88f30fbb845.manifest. Component 2: C:\Windows\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24483_none_2b200f664577e14b.manifest.
WhoCrashed log:
On Wed 3/25/2020 9:42:41 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!PoUnregisterSystemState+0x22FD)
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8001700EE0, 0xFFFF, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred. A page table page has been corrupted.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Updated to v.2.3.3
Will that fix it?
Probably not. The problem is most likely to be due to a bug in the sound card driver.
Check on your computer manufacturer’s website to see if more recent drivers are available.
